winnie
- Springfield, MA, USA
- Electric motor research
You can have electric fields or magnetic fields. Voltage creates electric fields, current creates magnetic fields. A _changing_ field of either sort will create the other, thus 'electromagnetic waves'.
A sufficiently strong electric field will have some effects on living things; for example birds simply will not stand on wires that are too high voltage...but I rather doubt that the electric fields created by 120/240V home wiring will be significant.
The effects that Karl has documented seem to be caused by magnetic fields related to unbalanced current flows. Fixing problems of unbalanced current flow has the benefit of being something that you can measure with well defined repair strategies. In addition you would almost certainly be correcting aspects of the wiring that were not to code.
A 'technical power system' would reduce the electric fields created by home wiring, because now every circuit would be at an average voltage of 'ground'...but as I said I do not believe that these electric fields are a significant issue, and hunting down the magnetic fields is probably much more supportable.
-Jon
-Jon
