Jerseydaze
Didnt this same sort of thing happen when Gfis first came out? Im to young to know.
Yeah, took awhile before they worked correctly.Jerseydaze said:Didnt this same sort of thing happen when Gfis first came out? Im to young to know.
electricmanscott said:The one that I did trouble shoot showed and "arcing fault" acording to the led on the breaker. Not an arc fault to ground, not an overcurrent condition.
peter d said:Scott, are these Siemens AFCI's?
Yup. Combo AFCIs have been available in the Twin Cities since January. They've been required since Jan. 01.brantmacga said:are any of you getting them yet?
You know what is important is not that the afci's work or not, but the fact that we are having to buy them!ptonsparky said:We just started installing AFCIs in Dec. They were the last of the non combination style. Happened to be on the job yesterday when carpenter complained that the 20 Amp CB was tripping before his Dewalt double insulated 2 wire miter saw would get to speed. Enough sparking at the brushes to trip the AFCI. Worked fine on the GFCI recepts in kitchen. Tenants may have to run cord to kitchen to vacum, but hey, the AFCI worked.
langjahr@comcast.net said:Some computer faults that take weeks to troubleshoot can be fixed in one afternoon by a data recorder device (a logic analyzer) that babysits the signals on dozens of lines until the fault shows up, and then dumps its memory and shows what happened just before the fault.
Of course, it costs kilobucks.
I don't know if anyone makes something like this for this type problem, but I guess it would monitor what the AFCI is supposed to trip on, along with line voltage and any other thing that might influence it.
This would certainly be useful for circuit breakers that trip for no reason that you can find once you get there.
You leave it in place until the fault, and the signals you need to troubleshoot are digitally captured in memory, just as if you were standing there at the time.
They have them for cars.
On the other hand, these things are supposed to filter our invalid glitches and trip on valid signals only. Maybe the next generation, Rev. A, of these things will solve all the problems that the salesmen denied that the first generation ever had.
I'm sure the thing worked perfectly in the lab!
electricmanscott said:Started with GE switched to siemens. Other job is Murray. Common denominator......?
ItsHot said:You know what is important is not that the afci's work or not, but the fact that we are having to buy them!
