AlbertL57
- Falls Church, VA
- Solar maintainer
Motor-generator sets?Also curious how the 'Frequency Changers' worked..............
Yes. ConEd provided steam to heat Manhattan buildings. That's those "funnel stacks" sticking out of the streets with steam coming out of them you see in movies.To NY Steam Load'.........for building heat maybe ?
I am quite sure they were. Solid state converters were a bit of a ways off yet...Motor-generator sets?
Not just heat but also used for cooling with absorption chillers.Yes. ConEd provided steam to heat Manhattan buildings. That's those "funnel stacks" sticking out of the streets with steam coming out of them you see in movies.
-Hal
AFAIK they still do.ConEd provided steam to heat Manhattan buildings.
It's probably on there because it was built in the early 1900s or late 1800s when frequencies were not yet settled upon, and had not yet run out its long service life, so was easier at the time to keep it working as-is until it could be incrementally upgraded to 60 Hz.I'm kind of surprised at the amount of 25Hz, but assume that's almost all transit/railroad loads.
I would guess that all of those plants had local feeders supplying the surrounding area, but not shown on the diagram. Maybe 66th St only served local loads, and wasn't connected to a tie line like the other plantsWonder why the 66 th Street generators are not shown connected to anything
