Quote:
We have a number of contractors that run 14-2 thru the ceiling and hit all of their lights. . 3way switches are all 14-3 dead ends that are both supplied from the light. . One of the 3ways will have a hot and 2 travelers but the other one has 2 travelers and a switchleg. . What would you use the white wire for with 2 travelers and a switchleg ?
My reply:
According to 200.7(C)(2) this is an illegal installation with multiconductor cable. Its a fine scheme in conduit where you can choose what colors you use.
A dead end 3-way wired with multiconductor cable (NMB or MC etc) must have the hot for its common, which is legal to be a reidentified white. This is the same reason you cannot run both the hot and the switched leg to the 4-way location box in a 3-way/4-way switching scheme. You can make it work, sure... send the hot down one three-wire's white toward a dead end and send the switched hot down the other end. It will work, but won't be code compliant.
Here is another fun example of a 3-way that will work, but isn't legal. Here in Oregon we call it a California 3-way.
Wink Wink Nudge Nudge
Take two switch boxes and a light box-- run a two-wire with hot and neut to each switch location. Take the power from the same circuit (Or, at least the same phase, since this aint legal anyways) to each switch box. Now run a two wire from each box to the light. (Single strand of THHN works just as well.. hell maybe even cat5e) Put the power's hot and neutral on the traveler screws on each 3-way switch, and use any conductor you like on the two-wire from the switches' commons to the light. Cap off or cut chort the unused conductors, and certainly no need to worry about that silly equipment ground. Land the wire from each common on the light's hot and neutral... one on each. Don't bother with wire nuts, tape is fine.
What you get is a system whereby either switch location being toggled changes the state of the light--from off to on or on to off--. You either have two neutrals at the light:OFF ; two hots at the light:OFF ; or one of each: ON.
I certainly don't recommend doing this, but recognising it sure helps in repairing the system to safe, legal, and working when you find it.
To be fair I haven't ever seen this in California, but plenty of times here in Oregon, mostly on K+T houses that were poorly remodeled with BX or early fish-scale romex.
Jack
