- Windsor, CO NEC: 2017
- Hospital Master Electrician
Two questions I promised to ask (I have an opinion, need input):
1.) You have a clubhouse in an apartment complex with a hot tub and a pool. There is a panel in an electrical room in the clubhouse, a panel marked "Pool" and two runs to be installed - one for the pool equipment, and one for the hot tub.
Can the hot tub at the clubhouse be wired in NM?
Can the pool disconnect be wired in NM?
2.) You have a patio outside the insulated walls of the clubhouse, with a concrete pad. The patio roof is a part of the clubhouse roof. The customer would like a paddle fan installed above the hot tub. There is a roof over the patio, a full back wall and the side wall is about half the depth of the patio, so 2.5 sides of the patio are open.
Is the patio outside?
How high must the paddle fan be installed over the water of the hot tub?
Is GFCI protection relevant in the determination of the height of the paddle fan?
I know this might sound goofy, all answers appreciated.
