The word "yoke"
Yoke=?
Yoke=?
In 210.4(B), the word ""yoke" is used. I haven't seen this word used at all in the code anywhere else. I finally figured out what was ment by it, but I don't understand why this word was used in the first place.:smile:
dictionary.com said:
yoke
1   /yoʊk/ Show Spelled Pronunciation [yohk] Show IPA noun, plural yokes for 1, 3?20, yoke for 2; verb, yoked, yok⋅ing.
?noun
1. a device for joining together a pair of draft animals, esp. oxen, usually consisting of a crosspiece with two bow-shaped pieces, each enclosing the head of an animal. Compare harness (def. 1).
2. a pair of draft animals fastened together by a yoke: five yoke of oxen.
3. something resembling a yoke or a bow of a yoke in form or use.
4. a frame fitting the neck and shoulders of a person, for carrying a pair of buckets or the like, one at each end.
5. an agency of oppression, subjection, servitude, etc.
6. an emblem or symbol of subjection, servitude, slavery, etc., as an archway under which prisoners of war were compelled to pass by the ancient Romans and others.
7. something that couples or binds together; a bond or tie.
8. Machinery. a viselike piece gripping two parts firmly together.
9. Also called fork. a forklike termination for a rod or shaft, inside which another part is secured.
10. a fitting for the neck of a draft animal for suspending the tongue of a cart, carriage, etc., from a harness.
11. a crosshead attached to the upper piston of an opposed-piston engine with rods to transmit power to the crankshaft.
12. (in an airplane) a double handle, somewhat like a steering wheel in form, by which the elevators are controlled.
13. Nautical. a crossbar on the head of the rudder of a small boat, having lines or chains attached to the ends so as to permit the steering of the boat from forward.
14. spreader beam.
15. a shaped piece in a garment, fitted about or below the neck and shoulders or about the hips, from which the rest of the garment hangs.
16. a horizontal piece forming the top of a window frame.
17. a Y-shaped piece connecting branch pipes with a main soil pipe.
18. Television. an electromagnetic assembly placed around the neck of a cathode-ray tube to produce and control the scanning motion of electron beams inside the tube.
19. British Dialect. (esp. in Kent)
a. the time during which a plowman and team work without stopping; a period of plowing.
b. a measure or area of land equal to over 50 but less than 60 acres.
20. a word formerly used in communications to represent the letter Y.
I don't really know ........but, my guess is something like # 8.:confused::grin:
"Yoke" appears 11 times in the 2008.
Art. 100 def of receptacle.
210.7(B)
220.14(I)
250.146(A)
250.146(B)
314.16(B)(4)
314.27(A) Exc.
214.27(E) Exc.
404.10(B)
406.4(A)
406.4(B)
The word Yoke is used at least 17 times in the NEC.Can You find them all?
Yes.
You are not supposed to pick on the new guys but cows are fair game.
OK:
In 210.4(B), the word ""yoke" is used. I haven't seen this word used at all in the code anywhere else. I finally figured out what was meant by it, but I don't understand why this word was used in the first place.:smile:
Welcome to the Forum!
The word yoke is also used in the UL White book with the same usage. :smile:
