Curious nerd
- Washington State, USA
AC distribution systems are sometimes designed with a safety device variously called a "ground fault neutralizer", "arc suppression coil", "Petersen coil", or "resonant earthed neutral". If you Google, try every possible mis-spelling of "Petersen".
It adds inductive reactance to cancel out the capacitive reactance of the power lines. This is supposed to mitigate line to earth faults.
Nobody explains how, so the reason must be obvious and I'm stupid for having to ask. I would have expected capacitive current, at 60 Hz and the low capacitance of power lines, to be a really small problem compared to the real component of the fault current.
Guess #1: When a line hits a tree, the tree is a capacitor as well as a resistor, so tuning the circuit can reduce the problem to the tree's conductivity.
Guess #2: If the line develops an arc to earth, then if it's running with current and voltage in phase, both go to zero at the same time and it's much easier for the arc to self-extinguish. At zero crossing there's no current to keep the air hot and ionized, and no voltage to restrike the arc. So, a tree branch swings in the wind, touches the line, draws an arc, swings back, and the arc goes out instead of being self-sustaining.
Guess #3: For the same reason, the protective devices can work better.
There are lots of references to the "what" of how the system works, but I've had trouble finding the "why" behind its benefits.
Thanks for your patience. It's not just me, there was someone here in 2008 asking a similar question. That discussion died from a language barrier.
