brantmacga
Señor Member
- Georgia
- Former Child
I'm sure many of you are now familiar with the BOCCI receptacle; if not here's a link to the product.
22system.com
There is now a TIA concerning this product.
The gist of it is, they will require a non-metallic box with a non-metallic cable/conduit entry, and you cannot have any circuit conductors leaving that box supplying another outlet. Also you will have to put a label in the panel indicating the location of the removal tool.
22 System
22 System is a comprehensive suite of electrical wall accessories available in multiple colours and configurations.
Exception: Smaller openings in building surfaces that accommodate one or more individual devices shall be permitted if all of the following conditions are met:
- (1) The outlet box that supplies the device(s) is nonmetallic.
- (2) The branch circuit wiring that supplies each device consists of a separate nonmetallic
cable assembly originating outside the box, or individual sets of conductors in a single nonmetallic raceway, all of which originate outside the box. Other than the connections to a single device, these conductors are not spliced in the box or continued to another device, and no other wiring or raceways enter the box.- (3) Each device is capable of removal from the building surface opening without being damaged. If a special tool is required for this purpose, the applicable circuit directory for the device records the location of the tool, together with a product code/QR code for acquiring a replacement if necessary.
- (4) All connections for each device to the branch circuit wiring are made with listed clamping-type wire connectors, which are supplied with the devices. The branch-circuit conductors are arranged to permit the connector(s) to be exposed after the device has been fully removed.
- (5) The device assemblies are listed for this application.
