jeff43222
- Minneapolis, Minnesota
So I'm playing evening electrician again, and I ran into a puzzler in a thermostat box.
I was called in to replace a 30-year-old thermostat that the HO told me didn't seem to work right. The room, heated with electric baseboard heaters, was either freezing or roasting. She went out to Big Orange (I know, I know ...) and bought a new thermostat (works for either 120V or 240V) for me to install. Here's what I found:
Inside the thermostat box were two 14-2 NM cables. The whites were twisted together, one black was connected to the line terminal, and one was connected to the load terminal. Everything was bonded properly.
The CB protecting the wires was a two-pole 15A breaker. Connected to it were the black and white wires of one 14-2 NM cable. Naturally, this makes me think the baseboard heaters are 240V. But the wiring in the thermostat box sure looked like what I'd expect to find with a 120V circuit.
So I got to wondering if a 240V thermostat is wired with one phase passing through the thermostat and one not (that would explain the wiring in the box). I tend to doubt it, though. Since most people around here heat their homes with gas rather than electricity, I don't have a lot of experience with line-voltage thermostats.
Here's where things get weird. I forgot my meters and only had a voltage detector with me. Both black wires (one line, one load) showed hot. This made no sense, and I figured one of the "hot" wires was actually showing induced voltage. To figure out which was which, I put a light bulb between each hot and the ground wire, and the bulb lit up for each. Now I'm baffled.
What I found in the panel doesn't seem to match up with what I found in the thermostat box. I couldn't find out if the heater was 120V or 240V, and I'm sure not going to guess.
Anyone have any bright ideas?
