dmagyar
- Rocklin, Ca.
I received a call Friday from a new client. They had a power outage in a sizable portion in their house and needed some help. I went over and started to look over the problem. In the first switch box I opened up the upstream neutral had voltage to ground, along with the ungrounded conductor. I've done some other calls where the circuit has lost the power, but this with the neutral becoming energized was a new twist. (without it being the fault of bad three way conneciton using the white wire). I began to open boxes and isolate the upstream feed and neutrals, but the circuit was not installed by any logic that I could discern. I pulled out some of my test equipment, my Greenlee 2011 for tracing the circuit, low voltage toner, and my trusty voltage tester but to no avail. Three hours later I called it quits for the night. I came back the next day and continued in the same fashion opening boxes and splices looking for the problem, but no smoking gun. Anyway after about three hours the second day I hadn't found anything that would cause the initial problem, so I start reconnecting the splices in the boxes furthest downstream first. When I had completed the splicing and turn the breaker back on, I see that the problem had disapeared, & the lights are now working as installed. Client was happy, he paid me and I left. But I was still stumped by whatever had caused this in the first place. Any thoughts on what it might have been?
What I did find was: three ways installed correctly by owner, alot of plug strip loads plugged in, a non functioning smoke detector on the same hot, removed no change and alot of switches that had been replaced by the owner, with very small tails which were cut out of the stab in slots, and then re-termed under the side screws. Also were two large groups of neutrals and hots inside one red wire nut respectively (about six wires each, replaced with gray wire nuts). (I did remove the small cut off wires from the slots of the switches).
