Thanks for the constructive criticism
Thanks for all the suggestions, which if I had not employed this time, then those will be filed for future use. I did mention that the folks were moving, but didn't accuartely relay how many boxes, & household items were piled everywhere, I would have loved to be able to post a picture of the overall mess, but didn't want to embarrass the HO. Oh also there were three dogs underfoot. Had I not been thinking myself that this took too long I would have done just like many before me and not posted anything of my experiences. I wanted to improve my performance by posting this situation. I also didn't mention that though I got paid I had discounted the whole bill to an amount which seemed appropriate, Karma not withstanding.
Just a few words to "220/221"; at the first box which I openned, the problem was Upstream, not downstream. This point turned out to be the tail end of just one of the branches of the circuit, which though closest to the panel wasn't the point where it originated. This circuit was propagated around the garage, and adjacent hall, laundry room lighting, one ceiling smoke detector, outside eve mounted lighting, yard (ground) mounted flood light with accompanying switches, and seven receptacles in the back bedroom. I had to get into the attic to determine where the circuit split and went in three different directions (that was the ceiling smoke detector). The attic unless those in your respective area are different was worse than the downstairs area with clutter, debris.
As far as experience thats a relative term and until you're faced with a situation that tests your "experience" that same tool doesn't increase in the power to serve you in the future. You can gain some insight by reading about the problems others are having, but it takes on a whole new significance by experiencing it firsthand.
