kbsparky
- Delmarva, USA
We recently encountered what I would call a bizarre installation. There is this service panel, and mounted directly underneath it is a trough containing the main incoming cables from the outside meter box. This wireway contains what I would call "unfused" wiring, and as such should not contain anything else.
Now the bizarre part was someone decided that they needed to install some circuits through this reserved space. Sooooo, they drilled a couple of 2" holes in the top and bottom of the wireway, and installed some 1-1/2" carflex right through it! The branch circuit conductors were then installed inside of the carflex conduit.
So, does this back-door method of installing a raceway inside of another wireway comply with the separation of fused/unfused conductor requirements?
