winnie
- Springfield, MA, USA
- Electric motor research
Wow. Every receptacle gets its own meter....
mdshunk said:Yeah, that happens quite a bit. When my kids were young, it took all I could do to keep them from hammering nails into the SE cable everytime they went outside to play.
dcspector said:and what state are You referring to?.....DC is still under the frigin 96? I am tested to 05 and You think that SER connector is a DRY location Damp ain't gonna happen ? Also, The SE must be protected 230.50? So what are You sayin ?
romeo said:I find that closing the meter socket in that way creates condensation and rots the siding in back of it. I once tried to pull a meter and ended up pulling the meter socket from the building.
infinity said:IMO the standard locknut would not be code compliant since the raceway is above the live exposed parts within the meter pan. A sealing locknut or Myers hub should have been used. Is duct seal a substitute for the proper fitting?
racerdave3 said:So just because your personal opinion is that a sevice that is done in SE looks like crap, it means that the job results in an installation of poor workmanship? I personally take great exception to that comment. Every installation that I have ever done that involved the use of SE cable has been "in a neat and workmanlike mannner" and displayed the highest level of workmanship AND CRAFTSMANSHIP.........and furthermore has never failed in any way shape or form. If you are so anti-cable, does that mean that you also have anti-romex issues when wiring residential? Are all of your installations done in MC cable, conduit? I think the bottom line is that the NEC approves acceptable methods for all installations, and the AHJ follows those quidelines in the inspection process. Any of these acceptable installations can be done in a neat and workmanlike manner by a skilled craftsman, or just thown together by a hack. If you feel that strongly about your opposition to the uses of SE cable for service installations, then perhaps you should convey your concerns to the cade making panels and have them exclude the use of SE cable in the NEC.
bikeindy said:Excuse me. The pic in the original post looks like crap
iwire said:Look this is not how this is going to go.
If you have a professional comment about it feel free to say it.
If all you have in mind is throwing stones than keep it to yourself.
1793 said:As stated in an earlier post of mine, this is something I do not see in my area so when I saw this installation and I was taken aback.
I think I was asking if this was a common installation in other areas.
bikeindy said:I know it is code compliant
stickboy1375 said:I was curious if only the north east uses SE cable? I can't see Southwire making the stuff just for us...:smile:
I think SE is used all over the place.stickboy said:I was curious if only the north east uses SE cable?
georgestolz said:Perhaps your question should be, "Is SE cable used outdoors in a permanent fashion anywhere but the northeast?"![]()
