Currently doing the finish work on an old structure that still uses knob and tube wiring. During the rough-in the local inspector asked me to clean up some open romex to knob-and-tube splices I had found in the attic that were done at some time in the distant past. Tracing out the circuit showed that one continuous run (approximately 80 feet) of old romex was spliced on one end between knob-and-tube and on the other between some old BX. At the knob-and-tube end my Greenlee Voltage Detector indicated that there was no voltage on the circuit. However, when I test the BX end the Detector registered voltage for the first ten feet after the splice!!! The Detector also registers voltage on the grounded conductor!!! What gives? This one has me totally confused.
[ November 12, 2003, 09:06 PM: Message edited by: jemsvcs ]
