While studying the NEC (2020), I came across the following question on a website:
Which one of the following conditions apply where Type NM cables are permitted to enter a panelboard through a nonflexible raceway without the cables being secured to the panelboard?
The following are the possible answers:
I would appreciate an explanation of the process someone might use to answer this question, rather than simply knowing the answer by memory. Is there a keyword or an idea that directs you to a particular section in the NEC? How do you narrow that section down to a particular subsection?
Thank you.
- The raceway extends directly above the enclosure without penetrating the structural ceiling.
- Because the cables are not secured to the enclosure with a fitting, they shall be strapped within 24-inches, measured along the cable sheath, of the outer end of the raceway.
- The raceway shall be at least 18-inches, but not more than 130-inches long.
- The number of cables installed in the raceway is not limited where the raceway length is not more than 24-inches.
Thank you.
