milemaker13
- Suburbs of Chicago
The atrium in our building has a 21' ceiling height. There are 16 recessed fixtures up there, several of which cannot be reached with ladders or the tiny lift that only goes straight up. Standard doors and ceramic tile floor prevent a boom lift. I am going to have to rent scaffolding to get to these fixtures.
The fixtures run 175w MH bulbs with external ballasts. We have replaced a dozen or so bulbs and half as many ballasts in the 5 years we've been here. The glass lense prevents successful bulb replacement with the "long stick".
I recently had a good experiance with LED while illuminating our flag pole and had the idea that maybe I could do something similar with the atrium lights, if only to allow more time between re-lamping.
I found bulbs made by Light Effecient Design, model LED8045M42. They are 50w, 277 volt 'bulbs'. They actually look like an oversized LED flashlight with a mogul base.
The current MH bulbs put out 14,400 initial lumens (9300 mean) vs. the LED at 4446 lumens. Both have a color temp of 4200k.
Has anyone had luck with this kind of retro fit? I've read a lot online and they seem to all agree these are suitable replacements. I'm worried that the folks in the front offices won't "like" the new light. My worst fear is after installing them, they will complain and want them changed back.
It is a pricy investment, around $3600 plus my time to swap all 16. I've done a little homework and discovered an $11k savings over the stated 50k hour life.
What do you all think here? Again, even if the actuall savings are less but the re-lamp time frame is 5x greater that is still a victory in my opinion.
There is another benifit that I can see.. Future bulb changes can be done with the "long stick" because I will be removing the glass lense from the fixtures. Hoping to never again have to climb a 20' scaffold in the fron t lobby. :thumbsup:
