James L
- Kansas Cty, Mo, USA
- Electrician
4 Square L Shaped Junction Box, Right Angle with (14) 1/2 & 3/4 in. Knockouts
4IN Sq L-Shaped Rght Angle Box
I'm guessing that this is a photo of the box going around a purlin?I had the same question and did see this picture, but ... this looks like a solution w/out a real problem.
Looks more like a steel tube beam. I could see this for as it appears to combine a 4sq jbox and a 4sq fixture box, and eliminating need to make up of box offsets. Cuts down on overall number of bends.I'm guessing that this a a photo of the box going around a purlin?
That would be a handy use, but I'd never have one on hand when the opportunity to use it came up.I had the same question and did see this picture, but ... this looks like a solution w/out a real problem.
That's what I thought. It's one of those things you could haul around for five years and never use it. Then one day you see it laying in your truck, and you decide to throw it in the garage because you haven't used it. Then the very next day, you need it. And you're an hour from homeThat would be a handy use, but I'd never have one on hand when the opportunity to use it came up.
Correct, was the pic not visible to you?I'm guessing that this is a photo of the box going around a purlin?
No I could see it but we don't work with purlins much so I wanted to know if that is what I was looking at.Correct, was the pic not visible to you?
Avoiding having to bend 90s?What's it good for??
