MTW
- SE Michigan
Send a private message with your contact info, not far from you. I can thread your riser.
MTW
MTW
Okay, was that
"Roger, Roger"
(from "Airplane"):slaphead:
I just got an upcoming job where I will need to rewire an old house and install new service. I'm going to use a metal riser for overhead 100A service, and I will need more than 10 feet of pipe. For the second piece, how would I thread it so that it fits into the meter hub?
spin the first piece into the hub.
spin the second piece onto the first piece. using a coupling makes this easier.
cut the second piece off.
deburr with file.
put weatherhead on pipe.
weatherheads can be purchased that don't require threading. buy one of those.
consider investing in a porta pony. with dies to 2". you will need it.
However, some questions like this make one wonder about a description of "I'm a licensed master electrician and electrical contractor". Many, maybe not every electrician, but every electrical or building contractor I know has a set of pipe dies up to 2"; however, very few residential contractors have stuff over 2". Most contractors will even have a motorized threading machine for up to 2".
I have been a self employed electrician for 10 years and doing my own side jobs for 5 years before that. I do not have threading equipment. I have needed to thread remarkably few times.
I am in the same situation as Electrofelon. I have threaded pipe many times while working for others but I do not own any threading equipment of my own nor do I have need of any. I use rigid for masts, but never needed more than 10 feet in length. I use rigid underground, but always use compression connectors and couplings where I have to cut a stick. If I were to need a pipe threaded, I would borrow equipment from another contractor or the apprenticeship hall.
I also don't own a large pipe bender. Factory bends work out fine 99% of the time. I have recently taken a couple of sticks of 2" EMT to the apprenticeship hall and used their bender for some offsets I needed. I'm more likely to buy a power bender before I buy threading equipment. Been in business 5 years.
had to thread and bend stainless rigid, that was pretty neat.
That sounds horrible. I hate working with stainless.
+1threading stainless conduit isn't difficult at all.
flood with tapmatic, not hi sulfer oil.
threads easily.
the reason it threads easily is you are turning at a very very
slow speed. if you drill holes at that same speed, using tapmatic,
and don't gall the material, SS cuts very easily.
the faster you go, the worse it gets. i was drilling 1/2" holes thru
304 SS, and you could see the flukes turning by individually.
was going thru 3/8" plate like butter. honest.
once you burn the metal, the show is over. it galls, and work
hardens, and carbide won't cut it.
bends nicely, as well. i spent a number of years in food packing
plants. everything is SS, ocal, or robroy.
+1
most people run drill too fast and get nowhere in a hurry when drilling stainless.
Applying much of what you said works pretty well with mild steel also, but mild steel you can get away with higher speed easier than stainless.
one needs to vary speed and pressure until you eventually find that sweet spot where extracted material is the highest, then remember about what speed that is and try to achieve it with every hole you drill. Start slow and increase speed instead of starting fast and decreasing speed to find that right spot.
Agreed. It seems one drives a motorized threader better after understanding how to use a manual one.learn these first>
then move on.....
