oldsparky52
- Wilmington, NC USA
Still representation.
Note that 120 volt AC is RMS voltage or effective DC equivalent voltage and that actual peaks are about 170.
Look where V2 and V3 are at relative to same time V1 is at the + peak. They are both at same level on the - side.
Look where V2 and V3 are at relative to same time V1 is at zero crossing, they are same voltage but opposite polarity.
Look at any point along the time line and see where each phase is at that instant in time.
Using your drawing, when V1 is at it's peak (+120V to neutral) V2 is at -60V to neutral. So the voltage somewhere gets to 208V V1 to V2. It appears that it will be before V1 peaks (less than 90 degrees) since V1 to V2 voltage is approaching zero after the V1 peak.
Do you know where that 208V potential between V1 and V2 occurs? Somewhere less than 90 degrees and greater than 0 degrees.
It's great that all of you share these insights.
