I've just seen something I've never seen and don't understand. In Chicago, a commercial space with a three phase service to feed only a a/c unit. The service had three wires, three hots. 240/120 with the high leg and no neutral. No ground connection either. The meter has both 120 volt phase conductors connected to the meter. The high leg passes through to the disconnect. There is a tap conductor running back to a "5th lug?" It is a special lug that connects to the meter in a style like the other connectors. Does that work like that? Is that phase considered metered like that? It has an Edison marked tape on it but no Edison tag to seal the meter box.
My plan is to replace the service with a new one. I plan on 100 amp 120/240 3 phase. I plan on a driven rod and a water pipe ground. No neutral. Can I reuse the meter and box? Is there anything else I should know?
Sorry. The meter and disconnect will be inside. The driven rod will be outside.
Thanks
Mike
Thanks
Mike
