Coppersmith
- Tampa, FL, USA
- Electrical Contractor
Please excuse my ignorance. I may be designing a three phase service and it's my first one. Client says they want a 400 amp three phase 240v service for a small workshop. I'll be looking at it tomorrow. I haven't contacted the POCO yet to see if they can supply this voltage directly, or I need to install a transformer. (480 to 240 delta/delta?)
Q1: Does 400 amps mean the total of the phase to phase connections (AB + BC + CA) is 400 amps, or each phase to phase connection is 400 amps?
Q2: The delta transformers I have looked at have a 120 v tap, but it's limited to 5% of the KVA. If I wanted more 120V, would I have to install a single phase transformer connected to two phases of my 240V output?
Q3: If the POCO can supply 240V three phase directly, I assume this would be four wires. Is there the same 5% of KVA limit on 120V?
Q4: If I supply a 480 to 240 transformer, how many KVA would I need for 400 amps?
