Cmac2210
- North pole, alaska
Hello... Im NOT n electrician, im just a homwowner. Recently during a renovation, I disconnected and removed an outlet.from a wall we are removing. Doing so made a three way switch at the bottom of a small stairway no.longer operable. So i took them both apart tonsee if i could trace the issue. To my surprise, thw wiring is all 2 wire. Ill explain what i have and hope that is helpful. 2, 3 way switches, top and bottom of stairs. In the box at the top of the stairs i have 3 sets of 2 wire - 1 set is the main line thatnis hot when i turn on the breaker, another 2 wire that powera the hall bathroom
