Three-way Switch
rbizzell
I recently wired a three-way switch in my basement. I ran 14/2 from the panel box to the first switch and 14/3 between the switches and then connected all my lights with 14/2. When I put in the pigtails to test the wiring the first light is brighter than the rest of the lights.
al hildenbrand
Minnesota
Electrical Contractor, Electrical Consultant, Electrical Engineer
Re: Three-way Switch
VD. That's funny :D
I'll bet it's differences in the lamps.
al hildenbrand
Minnesota
Try moving the lamp that seems bright to another of the fixtures.
Does the brightness move with the lamp?
charlie b
Lockport, IL
Semi-Retired Electrical Engineer
Can you give us information on the wattages and the distances involved?
physis
I was thinking the series thing, it only has to be series at one of the lighting outlets.
LarryFine
Henrico County, VA
Oh, what the hell, I'll join in!
If you remove one bulb, do any others go out? :p
al hildenbrand
Minnesota
Or maybe those fancy peril sensative glasses that get darker the closer one is to peril.
They have the words "Don't Panic" on them.
:D
mikeames
Gaithersburg MD
Teacher - Master Electrician - 2017 NEC
How would being in series cause this???
Current is the same throughout series circuits. Different bulb would do it.
hurk27
Ok I'll take a stab:
Draw three fixtures in line with hot terminals at top and neutral terminals at bottom. Now starting from left to right number 1, 2, 3. between 1 and 2 connect the neutrals between 2 and 3 connect the hots, feed a neutral and hot from last 3-way to 3, now accidentally ground fixture 1's hot Viola, you now have what he described. :(
Edit to add: And spell!
[ July 13, 2005, 12:59 AM: Message edited by: hurk27 ]
physis
We could use you on our drawing s team, I'm not so sure about the spelling team. :D
hurk27
Ok how's this for a first: :D
