TwistLock
- California
- Electrician
NEC 2020  TIA 20-8  Reference: 551.71(F)   TIA Log #1474
1. Revise 551.71(F) to read as follows:
551.71(F) GFCI Protection.
All 125-volt, single-phase, 15- and 20-ampere receptacles shall have listed ground-fault circuit-interrupter protection for
personnel. The GFCI devices used in RV site electrical equipment shall not be required to be weather or tamper resistant
in accordance with 406.9 and 406.12.
Informational Note: The percentage of 50 ampere sites required by 551.71 could be inadequate for seasonal
recreational vehicle sites serving a higher percentage of recreational vehicles with 50 ampere electrical systems. In that
type of recreational vehicle park, the percentage of 50 ampere sites could approach 100 percent.
Ground-fault circuit-interrupter protection shall be provided as required in 210.8(B). GFCI protection shall not be
required for other than 125-volt, 15- and 20-ampere receptacles used in the recreational vehicle site equipment.
Informational Note No. 1: Appliances used within the recreational vehicle can create leakage current levels at the
supply receptacle(s) that could exceed the limits of a Class A GFCI device.
Informational Note No. 2: The definition of Power-Supply Assembly in 551.2 and the definition of Feeder in Article
100 clarifies that the power supply cord to a recreational vehicle is considered a feeder.
(Apologies if this has been discussed before):
I read this TIA as RV 'Parks'. Not residential. Residential being covered in 210.8. So an exterior residential 30a/50a receptacle (for an RV) would require GFCI as well as WR. Again with the WR rating for 50a receptacles not becoming effective until 2026 only applying to RV 'Parks'.
Am I misinterpreting ?
