espiritiv
New member
- Portland, OR USA
So i have a bathroom remodel i am going to do soon. The house is built in 1970s and no work has been done on it yet. I wanted to get my scope of work together for the electrician.
The bedroom and bathroom are each on there own 15A 1P circuit breakers, but the wiring is a shared neutral. I know this was not against code back then. With the upgrade of the bathroom i need to install a GFCI circuit breaker, rather than put a GFCI receptacle as the first receptacle in the bathroom circuit. (why do this?, because my bathroom receptacle will be a USB/receptacle type.)
Here is the question: Can i put in the new GFCI breaker for bathroom, and use a tie bar to meet 210.4(b) to simultaneously disconnect when the GFCI trips? Or is it worth the time and money to pull a new set of conductors from the basement to the attic, to connect back to the bathroom circuit so that it has it own neutral wire?
