Tightening Torque for Screws
hashim
UL 486B, table 21 talks about the tightening torque for screws. What is the significance of A and B value in the table. Is it the tolerance limit for the tightening torque? Can any one help me out?
jim dungar
Wisconsin
PE (Retired) - Power Systems
I have never seen the UL486B table you are talking about. However, in a different UL standard the torque tables for slotted screws have different columns for different slot sizes.
Rockyd
Nevada
Retired after 40 years as an electrician.
I've always used the chart in the NECH in 110.14. Now before anyone can say NECH is not code, the notes explain that this is the chart that UL uses...thus making it codeworthy. Anything technical will have it's own listing in the instructions per 110.3(B).
Rockyd
Nevada
Wait till everyone has to start following the ad nauseum regulations imposed upon the oil industry. Torquing is just the beginning (EVERYTHING gets torqued). One has to have a cast iron stomach at times to face "rules put upon the industry". Sure, I want a safe work environment, but I want reality to be my guide lines. Not in bed with the oil companies, but they have wrote a lot of my checks. It's surprising that we don't pay more for gas. Just look at what they pay in Europe.
nolabama
new orleans la
would a torque screwdriver be worth it - you guys say only a small precentage of electricians use them - they are only a couple hundred for the nicest ones
76nemo
Ogdensburg, NY
Pierre, if you are asking me, I am referring to a handheld torque screwdriver. I have a 3/8'" torque rachet drive that I use if I have to redo a service. I have another friend that uses torque mark/paint that I am considering using. I haven't used it yet, and I know my local inspector will question it. I really like the idea, but I don't know anyone locally who uses it, we'll see how it goes. I figure I could use it at the meter line and load side and at the main.
Anyone else here use it? Why not?
electricalperson
massachusetts
i have the klein torque screwdriver and a couple klein torque wrenches. i dont torque screws on receptacles or other devices. i torque connections on breakers and service equipment. i do torque connections on certian devices. most residential devices dont get torqued
nakulak
I have a 1000v torque screwdriver I bought on ebay last year for 65 bucks - its not good for 1000 v anymore but works great and I like the fact that I'm now less likely to overtorque screw connections on gear and such. I use a small and large torque wrench for assembling any sizable gear. I really like having the torque screwdriver around.
