paul
- Snohomish, WA
I see you are a Telcom power engineer. I've been wondering lately about something. Grounding in the CO's. With all the redundant grounding happening, this has got to produce all sorts of grounding loops. I have to ground the AC at the main, every panel in the building, every transformer, ATS, water main, generators, rectifiers, ground rings, ground wells, etc. I also have to pull grounds in every conduit. I see nothing but ground loops all over these buildings. Doesn't this cause ground loops that can interfere with the switch as well as the AC electrical equipment???
