I made the service call today. 5 units total and one house meter. Each unit has a 50 amp main and 4 circuits total. All major appliances are gas including the house water heater and laundry. I didn't find anything suspicious at all. I pulled the meter, checked that the meter was the right one on the utility bill. With all breakers on, I had like 2-3 amps on each phase. We unplugged everything in house and had 0 amps.
Here is the only thing I found- It is a pushmatic panel which means that the breakers screw into the bus. The main breaker fell right out when I had the cover off and was turning it off and on. That means that the connection was loose on one side of the main breaker. Very loose. It also had burn mark right where the breaker screws in.
Could the loose connection create more resistance and thus a higher bill? Thats all I have right now. We did sign the tenants up online so that they can monitor usage and will keep track of what time of day the most power is used.
a loose connection will generate heat, but will also cause a voltage drop to the connected
loads, reducing their consumption, especially with incandescent loads. it balances out with
most resistive loads. motor loads will draw more with the voltage drop, but again, the refer
is about the biggest load, unless they have AC.
unless the voltage has a parallel path to ground, which will be just another load. i have seen
wires shorted in a conduit, bleeding current to ground, but not pulling enough to trip the breaker.
12 amps load on something 24/7 adds up...
assuming you were there during the day, if you had a grower tapped in, you'd a picked it up...
those guys set their timers to run during the day.... i remember one, who had a farm in his garage attic,
and the timer had them on at night, and the light leaks coming out here and there looked like close
encounters of the third kind... you could see it driving by at night
my vote is common area lighting on a time switch.
something i discovered in a rental unit i occupied a long time ago, was that the hot water on the
unit and the laundry area hot water were cross connected, in a wall somewhere.... didn't know
until after 6 months, when the pilot went out on the laundry room water heater, and my shower
was cool on full hot.
where are you gonna find that cross connect? geez.. and i wasn't gonna pay for half of everyone's
hot water on 5 coin op machines..... so i shut off the water heater and turned my pilot off.
my ex lived there after we separated and divorced for almost 15 years total.... every so often the
pilot would go out on the common hot water heater, and i'd go relight it, so everyone had hot
water for those coin op machines.... i *am* thoughtful...
