garyfitzgerald
Is there a way to calculate an air conditioning load if all you have is the size of the unit in tons? Applied voltage is also known. 208v 1 phase - 4 ton unit. This is a hermetically sealed compressor.
I usually use 1.5 KVA per ton, for AC units in the 2-5 ton range, but it can vary a lot.
How about a source??1 Ton of refrigerant =3.5 KVA
Ronald, your book is sloppy if it equates power to energy. Unfortunately, some authors are careless in this respect, and this shows a lack of engineering discipline.Originally posted by ronaldrc:
Rattus I did not mention a heater element.
These figures are form a HVAC tech. book
1 watt=3.412 BTUs we are talking about cooling with a air conditioner not heating with a heat pump or reverse air conditioning. Which they claim is more efficient than resistive electric heat.
Ronald![]()
