hardworkingstiff
- Wilmington, NC
Email from a Non-Customer
I bid a job 4 months ago, and this is the response I got from the customer.
I recently sent him an email inquiring as to how the job went. This is the response.
I don't expect I will get any work from this person, but at least I didn't have to fight about the money with him, and he did find out is was not as easy/simple as he thought.
I have a saying, "I work for money".
I estimate at most there is $1,000 in materials. Therefore if you are
charging $100 per hour (which is high) I calculate 40 hours of labor. Now I
really don't think this a week job. At this price I will probably get my
son to help me and get an electrician for some of the connections if needed.
I have done electrical work in the past and believe this is an excessive
quote.
It was awkward as you had anticipated and materials exceeded what we had
estimated. There was also a great deal of work to do in pulling an extra
wire from the fuse box in the garage to the conduit under the porch to the
pier as although it had 4 wires only 3 had been pulled underground to the
pier. We were running 220 to the boat lift and then 110 back for lights.
I had preferred to go with you but your estimate was almost $2,400 higher
than another certified electrician's quote. I went with a friend that has
done a very good job but he has probably spent a 100 man hours as he was
learning on the job. He did bring a friend that was an electrician over to
check his work.
In general I don't use friends for this type of thing but the guy has been
out of work for some time and he estimated it would only take 2 to 3 days
including water to the end of the pier. Oh well.
Thanks for your follow up and may contact you in the future for other work
although you seemed very busy on the one customer you had at hand. For
future reference what is your hourly rate?
