Tools for quality work
For romex rough in or multiple wafer lights Rackatiers Crocks wire strippers. Klien has terrible ones
A good rechargeable headlamp 500 lumins min
An old beater screwdriver
Drill taps
A good 3/8th socket set
What makes the Rackatiers Croc's wire strippers great in your opinion?
I have a variety of Klein and Ideal wire strippers and don't have any issues with them. Do most people here just use a razorblade to strip larger guage wire? Anything from AWG #8 to #2.
Oscillating tool is a necessity when doing old work in residential. Dremel tool is seldom used but it can get you out of a jamb when nothing else will work.
I use the Ideal solenoid tester to carry around with me. If I need my meter I get the Fluke out of the truck. I figure the less I carry the Fluke the smaller the chance of leaving it behind or dropping/breaking it.
I use my Dremel (Milwaukee) all the time. If you have a socket head screw stripped out, you can cut a slot in the head and remove the screw with a slotted screwdriver. Some KOs, especially in meter bases, won't knock out without taking more rings out than you need. Take the Dremel and cut the welds, the KO's will come out easy.
This is specific to romex strippers. The Klien has terrible handles and Ideal have 2 sizes 1 for 14 and 1 for 12. The crocks are right in the middle and cut clean. My ideal romex strippers only ever lasted a year before getting dull. The crocks last and last I've gotten 3 years out of them. I do have some klien forged wire strippers that are 7 years old now and still work good but they aren't romex strippers
On the larger size wire I use a knife passed 6. 8 and 6 I use my strippers opened up so they don't score the copper. Idk of anyone who uses the fancy splice knife or adjustable stripper for large sizes
Ah okay, nearly everything at my facility is tray cable, or RMC using THHN wires. I don't have much exposure to NM.
I have a pair of Southwire Romex strippers and they seem pretty good. You have to put them on the cable straight. If at an angle when you strip the outer jacket you can nick the conductors
