Hi,
I finally found this site while surfing for information about the NEC, Grounding Systems, and CATV Coax shield ground.
Maybe you folks can help. I recently tried to get an extra drop installed in my home in Orlando by Bright House Networks (TWC) to get broadband internet. Bright House contracts out all installations to what I guess are all independent installers.
Well, The installer comes out and I show him where the two current drops connect to the incoming cable via a splitter. The splitter is grounded via a bare copper ground wire that goes into the soil. It then and goes around the side of the house connecting the telephone demarc, cold water spicket (cold water pipe), and finally the power meter. So the cable is the last thing on the line and the power meter is the point of origination.
I thought this was standard and to code, but this Installer tells me that cable company has strict rules and that not only the new drop, but the existing one will need to be moved/re-run from the cable box to the bottom of the power meter and grounded there. I ask why can't we just run a new ground wire directly from the power meter to the cable demarc if there is a concern about the ground. He tells me it (shield ground) has to be connected directly to the meter.
Does this make any since to you? Its a free install so I guess he would be billing the cable company for all the additional work. I just told him to go home and I asked for a different installer to come out this Friday.
Is there anyway I can test/prove using my Multimeter that the ground system is correct?
Thanks
-Daniel
[ February 04, 2004, 03:01 PM: Message edited by: danhtcfl ]
Thanks
-Daniel
