timmermeier
- alton il
- electrician
If i use noalox on lugs in a panel does it change the tork spec. for the lug ?????????????????????????????????????????????????????????????????????????????????????????????
Never gave using Noalox a thought when I always applied a little on short flimsy screws on 100 amp circuit breakers. Several times in hundred year old damp basements ( actually cellars because they were below grade ) I found the breaker screw seeze so it would not turn. A few times had halve of the screw head broke off while attempting to loosen a screw.The torque spec is usually for dry threads, so keep the noalox of them and you should be fine.
