Re: Torque Wrench
Originally posted by roger:
Check out, this article on why you should not retorque.
Roger
Roger -- the article that you referenced is good.
The last part of that article states: "
Is it O.K. to check the torque on a connection? Absolutely, but any further action should not be taken until the condition of the connection is evaluated."
My question is -- how do you "check the torque" on a connection without "retorqueing" it?
The only way that I know to check the torque of something is to set a torque wrench to the proper value, then see if it "clicks" without turning the setscrew or nut any further. If the setscrew or nut turns before the torque wrench "clicks", that tells me that the connection was loose or under-torqued.
Roger and/or Don (or anyone else):
I'm not arguing, I just don't understand.
Will you please explain this so my 3 remaining brain cells will all light up together and say "Ahhhhhhhh"?
By the way, if there is clear evidence of heating, I agree that the connection should be taken apart, damaged parts replaced, damaged wire cut back to good conductor, everything cleaned, oxidation inhibitor reapplied and everything reassembled with proper torque applied.
But I'm still really confused over the issue of how you are supposed to "check the torque" of an existing connection.
Edited to add that I was asking for further clarification from both Roger and Don (and from anyone else). And to fix some poor wording on my part.
[ July 14, 2005, 11:58 PM: Message edited by: tx2step ]
