FionaZuppa
- AZ
- Part Time Electrician (semi retired, old) - EE retired.
And, in the auto trade, lug nut torque is different when a lube like Never-Seez is used.
well, sure, maybe, myth perhaps.
i beat the balls off my 4x4 in AZ desert, often, 33's on 16" alloys. other than installing extended wheel studs and using hollow nuts (the studs stick out end of nut), i use OEM torq with a crap load of anti-seize. never once since 2006 (because its a 2006 truck) did i ever have a lug come loose, never had a warped rotor, nothing.
if it was happening elsewhere (maybe in 1986) then perhaps some other engineering barf was the issue?
but ok, whatever you folks think is good, i'll go with what you say
