ramsy
NoFixNoPay Electric
- LA basin, CA
- Service Electrician 2020 NEC
First trouble call I had to walk away from.
Relatively new NM cable home, no crawl space between floors, customer says lights stopped working one day. Can anyone come up with a new plan or procedure for me to try?
Solenoid tester results:
1) Dead wires going to light switches x 2. (opposite side of same wall)
2) All 120v breakers at panel were energized, nothing tripped.
3) All receptacles had power, along same wall as switches.
4) Switch leg continuity to receptacle ground. (OK thru bulb filaments)?
Fox & hound results:
1) Tone shows same wires on both switches. (boxes not back to back)
2) Tone follows (H,N) circuit behind drywall in several directions.
3) No loose wires in boxes or upstairs switches, traced with fox & hound.
4) Same tone not present at de-energized panel, neither Hot, G, or Neutral.
I told customer cutting into walls to re-feed the lights is a last resort.
