gar
- Ann Arbor, Michigan
- EE
150405-2121 EDT
GoldDigger:
I should have been more clear. Hysteresis can not be ignored. The magnetizing current drives the ferromagnetic material to some flux level. When the magnetizing current returns to zero the core material flux does not return to zero (hysteresis), but to some substantial value, the residual flux density.
If we next apply magnetizing current in the direction of the previous excitation, then we start from the last residual flux level, and increase to a next peak and higher residual flux level. Because of the characteristic of saturation of the core the magnetizing current has to increase to a greater level than before. This is because there has to be a balance between the counter-emf from the core with the excitation voltage.
As an aside, by this technique I can build a counter with square loop material that does not go into saturation until X number of current pulses have occurred.
GoldDigger:
