I am to do some work on a small commercial building in a remote area. They want me to install a 200-amp service on the outside wall and right behind it on the interior wall a 200-amp panel. The area is Government owned and they have requested the service not be metered. For the interim they would like there to be a generator transfer switch so they can run the building with a generator until they provide hard power to the area. After doing some thinking, code hunting, I was under the opinion that I could use the 2 pole, double throw, 200 amp transfer switch as my outside disconnect,( Middle position of switch is Off ) and also as my service equipment. If I put a main, 200 amp breaker inside on my electrical panel, it would act as my over current protection for both the generator or utility loads. The panel would be at the shortest possible point from the outside wall, (right behind the transfer switch) so I am not seeing a problem with this. Anybody see an objection? They have told me that if the ever bring power into the area, the service to the building would be overhead, so I was in the line of thinking that I would put a overhead service drop out of the top of the transfer switch for future use.
Thanks in advance.
Thanks in advance.
