There was job where my boss test a deiesl generator with transfer switch seperate from both the generator and the main breakers to the company electric service 2000amps and 460volts. The transfer switch has selector type switch that indicates which test you are puting the generator in. At the start of the test a safety man told my boss he needs to be dress in arc flash gear to perform this test even though there is no labels on equiment stating the class of ppe to dress in.
Was the safety peron right ? After a pow wow with the two sides it was discovered he could not do the switching because he is not trained to do this work even if he is there electrical call person. There person is not around for this to be done.
If anyone has anything to add to this good or bad please do.
