Transformer and Delta To Delta fed with wye
dm9289
Industrial Maintenance Electrician
Pennsylvania
Industrial process repair/ maintenance Electrician
At the factory I work at we have a 480Y feed from utility. We run many 1980/1990s DC drives and I believe these transformers may be for isolation. Original Engineers are no longer with us.
Questions does a delta/delta transformer have a problem being fed from a wye?
If it is ok to feed delta/delta with a wye would the output of transformer act as a delta?
I assume yes?
There is a small dash symbol by H1 and X1 what does that indicate?
Thank you for your help and patience
I assume yes?
Yes, you can feed the delta primary of a step down transformer with the three current carrying conductors from a wye service. The secondary of the step down can either be delta or wye depending on the transformer; in your case (delta -delta) the secondary would be ungrounded delta.
The Delta primary is just the way that the transformer is internally wired. You can fed it with 480 volts and three conductors from either a Delta or a Wye system.
Thank you trying to figure out why some choices were made
Thank you
Ours is just 480 to 480 no step down so that’s why I assumed it was for isolation or changing to ungrounded delta to reduce trips
The dash represents the relationship between the windings.
Angular displacement between the windings.
Those show no displacement between the windings
Aka Dd0
Would that be similar to phasing dots or am I way off
Thats dot convention. It indicates the polarity of the windings. One lead in each winding is marked with a dot. When current flows into the dot in the primary, the induced currents flow out of the dots in the secondaries.
Aka Dd0
Correct.
Confusion comes with Wye windings, where the dashed line comes from the common point. Most people never see a de!ta-delta so they think the dashed lines represent the ground connection point.
