captain kirk key
- California
- Detailer
Are there any code violations if you install a transformer on one side of a wall and install the high/low boards in the same wall, facing another room? In other words you have room A, this is where the TX will be located. Room B shares a wall with room A and the panels are recessed mount and will be mounted in this wall. The low board will be well within 10f and not require disconnecting means.
