mikehughes8
- NC
I am hoping that somebody in this forum is familiar with substation maintenance and testing particularly as it applies to cables and transformers. I have been struggling to determine what advantages AC Power Factor testing has over the DC Insulation resistance test. The insulation resistance test measures leakage current through a systems insulation and returns a test value usually in the MegaOhm range. The returned value is simply a funtion of the applied test voltage divided by current returned to the test set.The power factor test returns a dissapation factor which is determined by the ratio of resistive current (Ir) to capicitive charging current (Ic). A dissipation factor below 5% in most systems represents a acceptable value.
Whichever ever test I choose to apply I answer the same question. Is the insulation good or bad? So why is one test better than the other? There must be a reason why someone is willing to pay $40,000 for a power factor test set when they can get an Insulation Resistance test set for $5000 and achieve the same result.
Any clarification would be appreciated.
