ctrane
- Jacksonville, Florida
Any and all help will be most appreciated. On a Low-Voltage General Purpose Transformer, what are the proper connections in terms of grounding? On the transformer chasis ground lug, should it be connected to the Primary side ground, Secondary side ground, or both? Also, is it appropriate to run a Ground Electrode Conductor (sized according to secondary over-current protection) from the Primary Ground bar (assuming it is point of service and ground bar is directly tied to ground system) and use that as the grounding of the separatley derived system, i.e. the secondary of the transformer, which in turn is tied to my Neutral (XO, assuming this whole question relates to a three phase, four wire system on the secondary). Is this grounding point of the secondary usually a lug that will accept multiple wires, or is this something that must be specified, because I will also have to run my equipment ground to the downstream panel from this lug.
Thanks
Thanks
