Pierre C Belarge
- Westchester County, New York
here is something I found via google. I cannot say this is valid, because it does not match what I believed to be true - although this is not my area of expertise.
"WYE-WYE: (No Isolation, least secure design) the primary and secondary coils are normally both grounded and some are supplied with an integral ground common to the primary and secondary. Environmental noise and background noise will enter the users facility unimpeded to every machine, drive and control as it is directly coupled from input to output.
An isolation transformer filters low frequency noise by the inductive coupling between primary and secondary and an electrostatic shield can be inserted between the primary winding and the secondary winding to filter high frequency noise that is coupled by capacitive interaction.
The WYE-WYE transformer connection has no filtering and all the noise on your power system is shared. The WYE secondary is very susceptible to harmonics. WYE-WYE systems generate considerable interference with communications systems and some jurisdictions prohibit their use. With the neutral not used or not connected to ground in a WYE-WYE system, the phase voltages become unstable and the entire system is susceptible to damage from transient voltage events and the harmonics now travel in the phase conductors. It is best to never try and parallel a WYE transformer with a DELTA transformer because they have a 30-degree phase differential"
