Mou
- schenectady , NY,USA
Hi guys,
I've Y-Y MV( 13.8KV sec /480V Pri) transformer and we connecting it to 3 wires BUS( 13.8KV) , So I've three options for the neutral connection on high side winding:
1- No connection ( floating)
2- solidly ground it
3- design ground reactor.
1st of all the three wires BUS is grounded through the up stream transformer reactor. in other word the upstream transformer is D-Y (115KV P/ 13.8KV sec) with the connection the Y to ground through reactor and the run the three wires only to the factory BUS.
So which one of the option will best work with fault current and best design practice?
