In an shed providing underground power a distance away to a home, it was decided to transform to a higher voltage at the road, then back to 120/240 for the home. At the road are there issues (cost/code) with feeding an 120/240 to 480volt transformer from an 120/240 panel so that lights and receptacle may be provided at the driveway entrance? I believe the Panel desired is an Siemens. Thanks again fir your input!
So what is the question? With proper thought, application of code and basic design this is all easily done. Yes this will get expensive when you consider all the requirements of proper grounding and bonding of a separately derived system and all of the OCPD, etc. Cost may be an issue, but one would have to wonder why cost is a primary issue for an application like this. After all, if you have a house that far away to require this and still need power for lighting, gates, etc. back at the street where the service is you just deal with it.
And what does Siemens have to do with the issue? This has nothing to do with a manufacturer. Proper design is just that and any brand will do.
There has to be more to this story.
