beanland
- Vancouver, WA
I have a semantics problem that seems to be endemic in the PV industry. Which side of the transformer is the "primary" and which side is the "secondary"? I see no clarification in the NEC. For a normal distribution transformer, the primary is the side connected to the utility source, the secondary is the load side. But does the same rule apply when used as a PV step-down? For example, 208Y/120V service and 480Y/277V PV. To me, the primary is the side closest to the utility grid because that is where excitation of the core comes from. Just because the power moves toward the grid, that does not affect the primary as being closer to the utility grid. But, this impacts 450.3 location of overcurrent protection and that is not clear. Does anyone have a citation from NEC that spells this out?
