I may have just burned up a 480-240 volt 112 KVA transformer and would like some advice before installing another. First of all, I bought this transformer used so it may have just been about to go anyway. Here is the application. I am coming into a rotary phase converter with a 200 amp service. It is a 50 HP converter. Each leg coming in measures 124 volts. The three legs out of the converter are 124, 124, and 218 volts (Delta). Measuring across the two low legs gives 248 volts and across the high leg gives 250 volts. I am going into the 112 KVA transformer on the low side with these three legs of power. I am coming off the 480 volt high side of the transformer to a plastic molding machine. I am using the taps from each coil to get close to 460 volts output. The max draw from the 240 volt side of the transformer is 62 KVA. The molding machine has a 100 amp main breaker in its enclosure and I have never tripped it. The transformer puts off a lot of heat and the coils have turned dark brown to almost black on one coil. This morning when I turned on the main hydraulic motor on the molding machine it tripped the 200 amp service breaker. I unhooked the transformer from the converter and now the phase converter will start and run normally so I am assuming a coil in the transformer shorted out. The transformer says it is rated for 278 amps on the 240 side and 136 amps on the high side. I am wondering if the 218 volt high leg coming off the phase converter is too much for the transformer to handle. I read somewhere that you can't input a higher voltage than the transformer is rated for but you can go less voltage without hurting anything. Across the legs I am a little over with the 248-250 volts as opposed to 240 volts measured across two legs but what about the single leg that is 218 volts?
Any advice would be greatly appreciated.
Jim
Aero-Mold Inc.
Jim
Aero-Mold Inc.
