Ok guys,
I've got a little problem here. What I am trying to do is power a project I am working on that has a total load of 100 Amps, which will probably be running 72-80 amps at all times. I need to supply everything with 120VAC single phase. So simply put, KVA equation would say I would need 12KVA transformer. Simple right. This is where it gets a little tricky. I am given by the company a 480 Delta supply. now to get 120, I would need a delta to wye transformer that does this would be 480 Delta/208 wye. At what KVA will this be rated at to make the total 100 amp load work? I have picked out a 15KVA transformer, but I want to be sure
I may have answered my question, I just want verification.
Thanks
Thanks
