Hey there everybody, I have a question regarding tapping a transformer secondary. I currently have a 50kva single phase transformer feeding a temporary office trailer that has a 125 amp main breaker panel and is located about 100' away from the xfrmr. The reason for the xfrmr is that the customer didn't have any single phase near the location of trailer. All they had was 230 3 phase. Used existing 3 phase disconnect, using A & C phases to xfrmr, to aquire 230 single phase and pick up a neutral. Now customer wants to add a second temp trailer next to first one. Okay, finally the question! Can I tap the secondary of existing transformer, as long as each set of conductors has its own overcurrent protection? I located 240.21(c), but that refers to secondary conductors that don't need overcurrent protection. This supply has dual voltage (230/110), so this would not apply, correct? If this is NEC compliant, where is it referenced?
